Now up to version 0.6, I’ve ditched the selection menu and splash screen in favor of using Long-Up and Long-Down to cycle between doors. Now tested on Android as well as iOS and in regular use on my garage.
Hi, Just tried to add this beta app to my Pebble watch but says its not available for Pebble Round.
Do you plan to have the app work with this model??
Cheers Monty
OK, thanks. I presume that you’ve entered your Particle user name and password in the configuration screen and it’s coming back with a “no doors” message, is this correct?
Are you sure that you have the account details correct?
Go to http://cloudpebble.net, set up your Pebble account to use it and import the zip file as a project. You’ll need to turn Developer Mode on on your phone, then in Cloudpebble, click Compile and View App Logs, then you can run the watch app and see all the debugging messages. If you copy these, change the URL’s (because they’ll have a security token in them) and send the log back to me, it may shed some light on what’s happening.
Sorry, I know that’s a lot of hassle, but the only other option is setting a temporary password on your garage and letting me play with your door.
I have a Pebble Time Round connected to my iPhone 6S.
I downloaded your beta app tonight as I received and installed my Garadget yesterday.
Installed the app, entered my username and password and bang, found my door, works a treat. Thanks a lot its great to be able to use my watch to open and close.
Just one little, little thing I noticed.
When i open the door,and it has finished opening, the screen still says “closed” until I press the “?” button and then changes to “open”.
When I close the door, and it finishes closing, the screen changes to “closed” without having to push “?” button.
I like the way it works when closing and thought that it may have a small bug that stops it behaving like that when opening.
its only a small thing, love the app and would be happy to pay for the final version.
thanks again
P.S. is there meant to be any colour on the screen? mine is all black.
I presume it goes from “Closed” to “Opening” to “Closed” again, is this correct? Or does it never say “Opening”?
Yes, the screen is intended to be black and white. I’m trying to support the widest range of watch hardware possible, and also to get the best screen contrast. I may add color later, but I’m more interested in getting it working properly.
