After a lot of difficulty getting Android to work on my S4 and S7 I found you had a new version on your site. I downloaded it and installed it on both units and everything seemed OK. After closing the door from the control in the garage neither phone recognized the change still reporting it open. After using the web access to check I found the web access reported correctly and then the phones updated and showed correctly. The phones were showing incorrectly for about 20 minutes till I went on web access.
The second problem is my iHome controllers built in to my cars no longer work from outside the garage. They do work when car is parked inside the garage. If I disconnect the garadget the controllers work normally. The door opener is a Liftmaster Security + (3255) and its about 10 years old.
With these 2 problems the garadget is not of much use to me. Hope you can help.
