Hi,
I use Garadget in conjunction with my Ring Doorbell to accept remote deliveries. Currently, I need to leave the Ring app, navigate to Garadget, open the garage door and then quickly navigate back to the Ring app to make sure the courier gained access and that the door successfully opened. This is sometimes problematic especially when the Ring doorbell decides to freeze up and as most of you will know couriers will usually do the runner if not attended to in a matter of seconds.
Is it possible to create a shortcut, accessible through the dropdown menu on an Android or as a button similar to the wifi, bluetooth, torch buttons etc when you slide the drop down menu on an Android? This feature will be very useful and allow me to open/close the garage door while in another app i.e Ring and others.
