Will it work it I set up using my phone as a hot spot? I tried that and it didn’t work either
It should work with the mobile hot spot assuming the security and other requirements are met. You’ll also need to use a separate WiFi device to run a client app for the setup.
Right I used a tablet when I tried
Alright, I would consider this a thorough troubleshooting. I’ll PM you for the exchange arrangements.
Ok thank you. I’ll make one more attempt with hot spot using the web link you sent me
