This morning, I used Garadget to close my door, but then stepped in front of the sensor, causing the door to reopen. I went to use Garadget again, but my door disappeared and I was forced back into setup. I’m away from home now with no way to connect to the door or monitor its status.
Are you able to login into the web interface at: https://www.garadget.com/my/ ?
I was able to login to both app and web, but my door was gone. I repeated setup and regained my door.
