Hi,
I’m very close to buying two of these for my double garage. In my scenario I have two separate sliding garage doors that run on rails parallel to each other, meaning that when one door is open the other garage is blocked by both doors.
I want to integrate the garage doors into my HA system (SmartThings, possibly Hass.io) with the ultimate goal of having them controlled by google assistant, however I would like to know if it is possible to have two Garadget units work in tandem via an interlock i.e. if one door is open the other wont open.
The reason behind this is because once the doors have the ability to be opened remotely via the web, we run the risk of being able to hit the others persons car when opening our door if the other person is in the process of parking when we send the open command.
If this is possible, can it be achieved through the native configuration or is it possible to customise something like this in ST or Hass.io?
Any info or links would be very much appreciated.
