I have had my Gradget installed for a little over a month without problems. Noticed today that it had lost connection. When I checked it was slow pulsing green. I removed power and powered back up and it reconnected and seemed ok. A short time later it lost connection again. This time after powering off and on it began flashing red.
There seems to be a pattern to the flashing, it’s not a constant speed. After it flashes about 20 times it will flash blue once and the laser will come on while the blue light is on then goes off and starts flashing red again.
I’ve tried holding down the M button but it has no effect. I’m not sure where to go from here.
