Any updates on when MQTT might be supported? Having random issues where the Home Assistant cannot contact the particle server for my Garadget. Happens maybe once per day. This then causes Home Assistant to change the status to closed after it contacts it again. I have homebridge-Homeassistant to display these in the Home app and give me a notification on open/close on the garage door. Had this happen around 2 am last night. Wife is getting a bit tired of it lol. Was hoping that by using MQTT this could be remedied.
Or if anyone else has had the same issue and has another workaround then that would be great as well. It isnāt happening in the actual Garadget app either. That still shows that it has stayed closed. So itās definitely something going on with the communication between home assistant and the Garadget server. Happens very rarely but itās enough to be annoying and making me think I need to try something else if I canāt fix it.
Error I see when this happens
17-02-19 01:52:42 ERROR (Thread-11) [homeassistant.components.cover.garadget] Unable to connect to server: ('Connection aborted.', BadStatusLine("''",))
On November 16 i had to sit and wait in my car for 20 minutes to open my garage door as the particle cloud was down and the keys to my apartment was in the garage.
Any news on the MQTT support?
Itās more than three months since you said that you hoped for something to show by the end of that month.
Iām tired of waiting.
Do you have a definitive date for a release or should i switch to a DIY solution and put the garadget device in the trash?
Apologies for the delays. It took a complete rewrite of the firmware from the scratch to make it more modularized and allow the commands/reporting from/to multiple protocols. The code is mostly ready, but requires a bit more polishing. Please stay tuned.
DIY solutions are welcome (you can even deploy it on Garadgetās hardware and publish it here), but if youāre not looking for a project, it may be more time efficient to wait a bit longer for the release.
After a complete firmware rewrite from scratch now itās ready for testing!
Those interested in early access, please Please PM me your device IDs.
After the firmware has been updated over-the-air, please access MQTT configuration:
put your unit into listening mode: press and hold āMā button for about 3 seconds until LED starts blinking dark blue
connect any WiFi device to PHOTON-XXXX access point and open http://192.168.0.1/ in the browser
using the web page re-configure WiFi connection and MQTT settings
submit to save, the device will reconnect to your WiFi network.
This process can be repeated anytime if necessary. Internet connection is not required.
Note that either or both Cloud and MQTT links can be used.
This firmware can be reversed if something doesnāt work out right.
The code was tested with Mosquito server.
