The Particle API is not that complex and itâs essentially what youâre doing with the maker channel, except it involves few more additional servers on the way.
If you want a working example of a call, you can go to the web interface, call the developer panel (F12 in Chrome), then go to âNetâ tab. Youâll see all of the requests and responses generated by the app. When you click the door to open/close it, youâll see the request that youâll need to reproduce in your web app.
If youâre still stuck, let me know the programming language you use in your automation website and Iâll try to produce the code for the Particle API call.
The android app is fine. I donât know, when i logged in to the web version the last time, but in the past it worked fine⌠You can see my login eMail in my profile⌠thanks for checking.
You might have a generic Particle account with the same email address.
I made modifications to the login form to resolve the ambiguity. Please try now after clearing browserâs cache.
Thanks, this was the problem. I created a particle account a few days ago with the same email address, because i thought i need one for the garadget API. Now i can see my door again, thanks.
Yep, curl is what I use for API calls in php code here.
Re. multiple notifications, here are the possible scenarios:
If thereâs something highly reflective in the path of the laser when the door moves, the sensor may be tricked into thinking that the door is closed. Solutions: cover the reflective surface or increase the threshold setting or increase the scan period
If door is too slow to start motion or if the reflective tag is larger than normal the laser may get another blink reflected after the command to open the door was received. Solution: increase the scan period or set the reflective tag in the way that it moves away from the beam immediately as the door starts moving.
the release rope gets in the way of the beam as the door moves, reflecting the laser. Solution: move the beam or cover the rope with something non-reflective.
Please let me know if any of this matches your situation.
