I’ve been working on a custom Alexa skill for a few days now. I made a quick video. Still more work to do before release.
Hi! I’d love to see the recipe you used to get this to close your door at 9pm if the door is still open.
Thanks!!
Aaron
Awesome. Thank you, sir
@Chris is looking for up to 10 beta testers for the native Alexa skill (no IFTTT needed).
Please reach out to him in PM for more info.
I can tell the Applet maker in the IFTTT app to this:
In the IF section I tell it to respond to the Amazon Alexa trigger service phrase “alexa open the garage door”.
When I tap the checkmark in the upper right corner it tells me to select an action service. What action service should I select, and what should I tell it?
Thanks.
Okay,
I’ve officially given up trying to do this all on my own.
Hi folks, I’ve been trying to set up IFTTT viscinity recipe and have failed to make it work and wondering what I could be doing wrong.
Can anyone be able to share the recipe w/ me? I’m under the organization mode at the moment.
Thanks a bunch!
@Suyhanwa,
Please describe what are you trying to achieve and how far you got trying to set it up in IFTTT.
Well, I want the garage door to open automatically when my car approach the address. and close when I leave.
I’d test trigger and action separately.
You can setup the geo-fencing trigger you want with some known good action such as push notification or email message. Once that is set, you can try Garadget action triggered with something you can easily control. After both parts are independently tested you can connect them together.
If you’re stuck with Garadget action, share the URL and parameters you’re sending for Garadget and I’ll take a look. Don’t forget to obfuscate the auth token when sharing.
roger that. will try tonight!
tried and trigger works well. It is definitely the action part. What should i do?
You can use something like https://www.hurl.it/ or http://requestmaker.com/ to test your requests to Particle API. The responses should give the idea what’s wrong.
good news! it’s finally working! i’m happy to report it back.
Hey everybody,
Garadget’s native IFTTT channel is almost finished.
Please try out the preview. More info here.
I have the same problem . Garadget is not seen through the web interface, instead, only my other Photon devices are.
When I try to link SmartThings with the Garadget app (last step under SmarrApp) it also does not see my Garadget, but only my other Photons.
Please advise.
Thanks
Albertus,
This happens because you have a Garadget specific Particle account and a generic Particle account under the same email address. I’d recommend moving the devices from one of the accounts to a new account with a different email address. This will resolve the ambiguity.
Thank you.
I guess I will change my account info for the Garadget then (only one device). In order to do that do I press the R(eset) or M(ode) button on the device?
To re-initialize the device in a new account, first put it into listening mode and then setup the new account with that device as if you just received it.
Is there a trigger to check the state of the door? I’d suspect one for Open, Opening, Closed, and Closing.
In this case, I’d like to check the state of the door in IFTTT while I’m leaving the house. Since there are times that I do NOT want to close the door automatically, I’d like to simply be alerted (via text or notification) that the door is still open.
Also, are there any triggers setup to save all activities to OneDrive or OneNote?
Thanks
Rick
