I am a long time owner of garadget but just got around to installing it due to home relocation and other priorities. Easy install and so far working flawlessly. Also I am a heavy user of Amazon Echo devices and garadget integrated well using “smart garage” invocation. However I am appalled at the lack of concern for security when voice opening of the garage door(s). You can voice order items from Amazon on Alexa but have to authenticate with a PIN number (Amazon calls it a voice code) for the order to be accepted. If you have any of the smart door locks you must give your PIN number to open the smart lock by voice but can close or status the lock without the PIN. It must not be that hard to implement and I would think it should be a priority.
Vann
