I have Garadget working with 2 doors (garage and gate), named carHOUSE and gate respectively.
I use both Alexa and Siri (via HomeKit). The Siri integration has no problem distinguishing the doors. Works as expected. The Alexa integration however opens/closes both doors when asked to open/close either door by name.
Silly question but how did you get it to work with Siri … Or where did you find the Homekit Setup Code. I just installed my device 10 minutes ago and its working fine but I wanted Siri automation to make my life even easier.
Cheers
Ian
Not silly at all. I’m running Homebridge which allows me to integrate non-Homekit enabled gadgets to work directly with Homekit.
If you have a bit a tech acumen it’s really not that hard to enable. You can run it on a spare PC, Mac or Linux box. I just picked up a Raspberry Pi, installed noobs, and then Homebridge. Works like a champ! See this post, it’s what I used : HomeKit Integration with Homebridge-Garadget Plugin
