Here’s the report mailed in by James D:
Here are some photos of my gate installation. The activator is connected to the manual activation circuit via two alligator clips (down near the outlet). I connected one to the switch and one on the other side of the lockout switch, so even if i disable the manual switch using the key, I can still operate the gate with the garadget. The sensor is a normally open reed switch, which is installed on a bracket near the hinge. Feel free to repost these in the forum. It is being used with the Apollo 1500 gate actuator system.
