Using the app from my iPhone, and it will sometimes take 12 times, or more of pressing the button to either open or close it. It says it’s opening/closing, but nothing is happening. The reflective circle is placed in the correct spot, and there’s no light coming into the garage. Makes it impossible to know if it’s actually open/closed when I’m not right in front of it. I have the latest version of the app.
Also have an issue of the app taking so long to even start and locate the Garadget, that I usually just end up closing the garage manually. All while I have a strong WiFi connection.
Im running into this as well. When i click open or close, I see the wall switch is turning off and I lose the clock setting so it seems to be communicating to some degree. The physical door doesn’t move but the graphics in the app does. Anyone run into this?
