Bought used garadget, can't claim device
As the title says, I can’t register the device. Setup through the app works until the last step when it attempts to verify ownership. It then errors out with a message that says “OOPS”.
I’ve also tried setup via USB. I’m able to configure the device to connect to my wifi network using the particle CLI. However, adding the device fails:
particle device add Photon-XXXX
Claiming device Photon-XXXX
Failed to claim device, server said: [object Object]
Evidently the device is still registered to the prior owner. I’ve searched the particle docs and haven’t seen any way around this. Are there any suggestions from this forum?
Please PM me the device ID (you can get it with particle identify CLI command).
I’ll look into it.
Just had the same happen to me. Thought I miss-typed my WIFI password. Had to go through the setup twice and Claim the device before it was successful setup.
Still great devices with lots of features-more than my Chamberlain MyQ installed in another location.
Bought used garadget, can’t claim device
I am also having the same issue
Setup through the app works until the last step when it attempts to verify ownership. I tried to claim device through ‘Claim Device’, but page does nothing
Jitesh,
What is LED indication on your Garadget at the time of the error message?
Same problem. Claim Device page does nothing. Any ideas how to get past this issue?
@garadget my landlord confirmed that the device is no longer connected in his account, but the LED is breathing cyan, indicating that it successfully connected to the cloud, but there’s some issue with ownership on my account. Am I able to DM you the device ID, so you can release it to be claimed by my account? Thanks! :folded_hands:
Got your device ID over the email. The unit was likely kicked out from the feet due to inactivity. Re-added.
Thanks yep it’s working now!
