Hi,
having an issue with my 2 garages, I’m using the garaget for control4. When i try to pause the door in motion, the garaget sends 2 pulses to the opener. The opener i have just needs a single press to pause while in motion and another single press to go back. the double pulse from the garaget essentially locks my door halfway, as the first pulse starts the door moving backwards, and the second pulse stops it again. once its in a half way position, the garaget only sends these double pulses, so all i can do is jog the door back and forth, is there a way to disable this double pulse thing? i’ve currently got it set to 0.3 seconds, which occasionally works as sometimes the door misses the second pulse.
