Can't login to app
I switched routers some time ago and now I can’t log into app anymore when I click “I forgot my password” it says "could not find the user. When I try to create an account it says user already exists. What gives?
I’m trying to setup again and have followed instructions to set wifi to proton-XXXX and I do that but the address 192.168.0.1 never comes up, left for a long time to open but nothing.
when i connect to proton-XXXX it says :no internet"
then in the app I get the error “Please try running setup again after resetting your Garadget and putting it back in blinking blue listen mode if needed”
For password reset please try the form online. The capitalization of email address (login id) should be the same as at the time of registration.
https://www.garadget.com/my/forgot.php
For setup: If you are using the app then start out connected to your regular WiFi. Only reconnect to Photon-XXXX when instructed by the app. If you want to use embedded web interface then do connect directly to Photon-XXXX (yes it will say “no internet”) and navigate your browser to http://192.168.0.1/
Did you try deleting the app and starting all over?
Followed directions and it tmes out with attached error every time
What is your result with the embedded web interface? The process described above that doesn’t involve the use of the app. You can use any WiFi enabled device for it.
I got it working, phone was trying to go back to cell service from wifi, had to force it to stay on eifi
