Do I have to reset/ delete the wholleeeee device setup to change the WiFi and WiFi password?
I don’t see ease of swapping WiFi.
For example I have 2.4 currently but wanted to switch to 5Ghz
Garadget does not support 5GHz WiFi band, but if you want to change the WiFi credentials you can do it by either re-running the setup or using the embedded web interface:
