I am trying to purchase garadget but want to make aure it will work with my door https://www.manualslib.com/products/Marantec-Comfort-220-3355137.html I see few ports 1 ,2 ,3 ,70, 71 but not sure where I will need to plug in the new unit. can you please confirm it will work and where to plug in before I purchase
Page 12
then (only guessing as I know nothing about this equipment) I would probably say the the connections are 70 and 71 as the Garadget acts as photocell. You have to take a risk on these things - I did and LOVE IT - 2 of my friends have now bought them - HIGHLY RECOMMENDED.
Sorry not much help - BUT if it does work - please post your instructions up on how you did it on the forum - and give me all the credit (LOL).
There is no difference. Inside of Garadget the terminals are connected to the normally open contacts of electro-mechanical relay which acts as a regular push button as far as opener is concerned.
Thank you for your reply. Another question - and forgive my lacking knowledge.
List item
I found a Step Down with these data - would it work if I set it to 5V, 3A (what about Watt) and connected it to port 1 (GND 0V) and port 3 (24V) on the garage door?: DC 5A Step Down Module performance and features:
Module properties: the isolation step-down module (BUCK) Input voltage: 4-38 V(please try not to exceed 38 V input) Output voltage: 1.25-36 V continuous adjustable Output current: 0–5 A Output power: 75 W
Working temperature: – 40 ~ 85 ℃
Working frequency: 180 KHZ
Conversion efficiency: MAX 96%
Load regulation: S (I) ≤ 0.8% ( 24 V input, 12 V output, load changes from 1 to 4.5 A measured)
Voltage regulation: S (u) ≤ 0.8% (12 V output, 4 A, voltage from 18 to 32 V change measured)
Power light: yes
Short circuit protection: yes (limit current 8 A)
Overtemperature protection: yes (After overtemperature automatic shut off output)
Input reverse connect protection: no, (if you need please in the input string into the high current diode)
Installation method: 2 pcs 3 mm screw
Connection mode: welding, V – IN for the input, V – OUT for the output Module size: 54mm23mm15mm(LWH)
This should be fine. Once you have it connected on the input side, I’d suggest confirming the voltage on USB end or testing it with some inexpensive USB device first.
Don’t worry about the Amps. Garadget only needs about 0.05A and all of these converters are offering much higher rating. It’s like horsepower which your car can deliver, but you only use as much as you actually need.
