I’ve looked through the forum but did not find whether garadget is compatible with the sommer s9060 pro+ hardware. I’ve found a reference however to their other model S9060 base+ referring to the terminal pins COM and Signal(Sommer S 9050 base).
My current installation exist of a runner (s9060pro+) and a wall control unit as described on vendor site (the rear installtion type setup). According to the manual of the device and my own observations the circuitboards on the wall control unit (pro+ unit) are the same layout as the layout on Sommer S 9050 base.
At the moment only the keypad pins are connected to the buttons on the unit and the pins labelled as 9 on Sommer S 9050 base are connected and running to the ceiling rail (https://imgur.com/2U0YwEq).
If I install the garadget unit, do I need to connect the pins on the unit to the two cables which are already connected using cage clamps (https://imgur.com/2U0YwEq) or do i need to connect the unit to the COM and Signal pins on the wall control unit ?
Thanks for any help you can give me. If the installation is succesfull, I’ll create a post with a short tutorial on the forum for the sommer setup.
