Can you please advise if the unit is compatible with a Chamberlain PD432D?
I’m not sure if this is a similar unit as the one mentioned in this thread: Installation with Chamberlain
Hi Rene,
Does your opener have a yellow “learn” button?
Per the manual, it does have a learn button (not sure what color).
Based on what I see in the manual (the type of wall console it uses and the fact that Security+ 2.0 is not mentioned) it should be compatible. Double up Garadget wires with those connecting wall button: two terminals on the left (Red & White).
