I have two Garadget controllers since 2016 and im starting to have intermittent issues with one of them. It will work fine for a day or so then it’s just suddenly stops, no laser flashing or any indication that’s the unit is even on. I simply have to unplug the USB power cable and it comes back on after it reboots. Any ideas?
Is there any sensitivity in the USB connector? I.e. if you lightly tap on the connector while the unit is online, does that affect the connectivity? Try a different USB power adapter on the chance that it’s the source of the issue.
Mine was doing the same thing, changed to another 5v supply and problem went away.
I tried that to no avail, ended up having a loose solder connection and emailed Garadget and they are taking care of it for me.
