I’m having a similar issue to another user from last October. My door only opens about 6 inches when triggered by garadget. The various scenarios are below.
If the actual door is closed, and the app sees it as closed, it’ll only rise 6 inches.
If the actual door is closed, and the app sees it as opened, it will open the door fine.
If the actual door is open, and the app sees it as closed, it will only close 6 inches, then stop.
If the actual door is open and the app sees it as open, it will close fine.
It seems like there’s just something weird going on if the garadget thinks the doors is closed, but i’m not sure why. I have not mounted my garadget or mounted the reflective stickers because as i understand it, that’s only for status monitoring, right?
Anyone else had this issue?
