slight update:
With the above configuration, I had that Home Assistant could only operate up or down. No stop commands.
However if the button is pressed in Homekit multiple times it can cause issues. I now have a check on the command so it can only go up or down via checking the state first.
HA sends MQTT commands to NodeRED, NodeRED updates HA on the state of the Garage.
NodeRED talks to Garadge via MQTT
It is also a little more simple than above, with the opening closing status also correctly tracked via HA as I can filter that information via NodeRED.
Home Assistant now shows the icon changes when opening / closing.
You can simply copy what I have, just make sure your topics are updated and server info.
[{"id":"103cc67.8a2a33a","type":"mqtt in","z":"53aabe5c.55603","name":"","topic":"garadget/Garage/status","qos":"2","datatype":"utf8","broker":"4d42f578.4cd4ac","x":180,"y":480,"wires":[["9a03810b.daabf"]]},{"id":"d9c45e63.3f094","type":"mqtt out","z":"53aabe5c.55603","name":"","topic":"garadget/Garage/command","qos":"2","retain":"","broker":"4d42f578.4cd4ac","x":1660,"y":840,"wires":[]},{"id":"8a1f7e79.9715a","type":"inject","z":"53aabe5c.55603","name":"","props":[{"p":"payload"}],"repeat":"60","crontab":"","once":true,"onceDelay":"0","topic":"","payload":"get-status","payloadType":"str","x":1370,"y":760,"wires":[["d9c45e63.3f094"]]},{"id":"9a03810b.daabf","type":"json","z":"53aabe5c.55603","name":"","property":"payload","action":"","pretty":false,"x":370,"y":480,"wires":[["452f6560.cc4e7c","ec717606.a82b18","df68cd3a.5620b","fbbcffad.76bf5","f3a60b8c.d33228"]]},{"id":"fbbcffad.76bf5","type":"change","z":"53aabe5c.55603","name":"Garage Ambient Light Brightness","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.bright","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":640,"y":480,"wires":[["ae035efe.81b26"]]},{"id":"f3a60b8c.d33228","type":"change","z":"53aabe5c.55603","name":"Wifi Signal","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.signal","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":570,"y":560,"wires":[["41381105.63a09"]]},{"id":"41381105.63a09","type":"rbe","z":"53aabe5c.55603","name":"","func":"rbe","gap":"","start":"","inout":"out","property":"payload","x":870,"y":560,"wires":[["1c3fea87.71a365"]]},{"id":"ae035efe.81b26","type":"rbe","z":"53aabe5c.55603","name":"","func":"rbe","gap":"","start":"","inout":"out","property":"payload","x":870,"y":480,"wires":[["1ad94266.96dfbe"]]},{"id":"ec717606.a82b18","type":"change","z":"53aabe5c.55603","name":"Time in State","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.time","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":570,"y":320,"wires":[["a2eca8de.38ba98"]]},{"id":"df68cd3a.5620b","type":"change","z":"53aabe5c.55603","name":"Garage Sensor","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.sensor","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":580,"y":400,"wires":[["1369d041.cd7bb"]]},{"id":"1369d041.cd7bb","type":"rbe","z":"53aabe5c.55603","name":"","func":"rbe","gap":"","start":"","inout":"out","property":"payload","x":870,"y":400,"wires":[["45a076f4.547c48"]]},{"id":"a2eca8de.38ba98","type":"rbe","z":"53aabe5c.55603","name":"","func":"rbe","gap":"","start":"","inout":"out","property":"payload","x":870,"y":320,"wires":[["930d9ec2.0a584"]]},{"id":"452f6560.cc4e7c","type":"change","z":"53aabe5c.55603","name":"Garage State","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.status","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":570,"y":640,"wires":[["fbffadd2.3b908","bbf82f95.bea51"]]},{"id":"7ae47241.c6ad7c","type":"mqtt in","z":"53aabe5c.55603","name":"","topic":"garadget/Garage/command","qos":"2","datatype":"utf8","broker":"4d42f578.4cd4ac","x":200,"y":140,"wires":[["628ec43e.083e6c"]]},{"id":"628ec43e.083e6c","type":"debug","z":"53aabe5c.55603","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":430,"y":140,"wires":[]},{"id":"a6c5f13.44eea1","type":"ha-entity","z":"53aabe5c.55603","name":"Garage Door State","server":"613f67e5.e69a28","version":1,"debugenabled":false,"outputs":1,"entityType":"sensor","config":[{"property":"name","value":"Node-RED Garage Door State"},{"property":"device_class","value":""},{"property":"icon","value":"mdi:garage-alert"},{"property":"unit_of_measurement","value":""}],"state":"payload","stateType":"msg","attributes":[],"resend":true,"outputLocation":"","outputLocationType":"none","inputOverride":"allow","x":1530,"y":640,"wires":[[]]},{"id":"6da1fc03.c126f4","type":"ha-entity","z":"53aabe5c.55603","name":"Garage Door Time in State","server":"613f67e5.e69a28","version":1,"debugenabled":false,"outputs":1,"entityType":"sensor","config":[{"property":"name","value":"Node-RED Garage Door Time in State"},{"property":"device_class","value":""},{"property":"icon","value":"mdi:timer"},{"property":"unit_of_measurement","value":""}],"state":"payload","stateType":"msg","attributes":[],"resend":true,"outputLocation":"","outputLocationType":"none","inputOverride":"allow","x":1560,"y":320,"wires":[[]]},{"id":"45a076f4.547c48","type":"ha-entity","z":"53aabe5c.55603","name":"Garage Door Sensor Reflection Rate","server":"613f67e5.e69a28","version":1,"debugenabled":false,"outputs":1,"entityType":"sensor","config":[{"property":"name","value":"Node-RED Garage Door Sensor Reflection Rate"},{"property":"device_class","value":""},{"property":"icon","value":"mdi:laser-pointer"},{"property":"unit_of_measurement","value":"%"}],"state":"payload","stateType":"msg","attributes":[],"resend":true,"outputLocation":"","outputLocationType":"none","inputOverride":"allow","x":1590,"y":400,"wires":[[]]},{"id":"1ad94266.96dfbe","type":"ha-entity","z":"53aabe5c.55603","name":"Garage Ambient Light Brightness","server":"613f67e5.e69a28","version":1,"debugenabled":false,"outputs":1,"entityType":"sensor","config":[{"property":"name","value":"Node-RED Garage Ambient Light Brightness"},{"property":"device_class","value":""},{"property":"icon","value":"mdi:brightness-percent"},{"property":"unit_of_measurement","value":"%"}],"state":"payload","stateType":"msg","attributes":[],"resend":true,"outputLocation":"","outputLocationType":"none","inputOverride":"allow","x":1580,"y":480,"wires":[[]]},{"id":"1c3fea87.71a365","type":"ha-entity","z":"53aabe5c.55603","name":"Garage Door Wifi Signal","server":"613f67e5.e69a28","version":1,"debugenabled":false,"outputs":1,"entityType":"sensor","config":[{"property":"name","value":"Node-RED Garage Door Garage Door Wifi Signal"},{"property":"device_class","value":""},{"property":"icon","value":"mdi:wifi"},{"property":"unit_of_measurement","value":"dB"}],"state":"payload","stateType":"msg","attributes":[],"resend":true,"outputLocation":"","outputLocationType":"none","inputOverride":"allow","x":1550,"y":560,"wires":[[]]},{"id":"23e8e7f3.39a128","type":"change","z":"53aabe5c.55603","name":"","rules":[{"t":"change","p":"payload","pt":"msg","from":"open","fromt":"str","to":"Open","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"closed","fromt":"str","to":"Closed","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"opening","fromt":"str","to":"Opening","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"closing","fromt":"str","to":"Closing","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"stopped","fromt":"str","to":"Stopped","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1080,"y":640,"wires":[["a6c5f13.44eea1"]]},{"id":"930d9ec2.0a584","type":"switch","z":"53aabe5c.55603","name":"","property":"payload","propertyType":"msg","rules":[{"t":"regex","v":"s","vt":"str","case":false},{"t":"regex","v":"m","vt":"str","case":false},{"t":"regex","v":"h","vt":"str","case":false},{"t":"regex","v":"d","vt":"str","case":false}],"checkall":"true","repair":false,"outputs":4,"x":1050,"y":300,"wires":[["c58dacd2.f6979"],["ffbeeacc.149518"],["301b6844.340c18"],["f1c84bf2.727868"]]},{"id":"ffbeeacc.149518","type":"change","z":"53aabe5c.55603","name":"Minutes","rules":[{"t":"change","p":"payload","pt":"msg","from":"m","fromt":"str","to":" Minutes","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1280,"y":240,"wires":[["6da1fc03.c126f4"]]},{"id":"c58dacd2.f6979","type":"change","z":"53aabe5c.55603","name":"Seconds","rules":[{"t":"change","p":"payload","pt":"msg","from":"s","fromt":"str","to":" Seconds","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1280,"y":200,"wires":[["6da1fc03.c126f4"]]},{"id":"301b6844.340c18","type":"change","z":"53aabe5c.55603","name":"Hours","rules":[{"t":"change","p":"payload","pt":"msg","from":"h","fromt":"str","to":" Hours","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1270,"y":280,"wires":[["6da1fc03.c126f4"]]},{"id":"f1c84bf2.727868","type":"change","z":"53aabe5c.55603","name":"Days","rules":[{"t":"change","p":"payload","pt":"msg","from":"d","fromt":"str","to":" Days","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1270,"y":320,"wires":[["6da1fc03.c126f4"]]},{"id":"fbffadd2.3b908","type":"rbe","z":"53aabe5c.55603","name":"","func":"rbe","gap":"","start":"","inout":"out","property":"payload","x":870,"y":640,"wires":[["23e8e7f3.39a128"]]},{"id":"dbc0234.12513e","type":"comment","z":"53aabe5c.55603","name":"Poll Status Every 60 Secs","info":"","x":1330,"y":720,"wires":[]},{"id":"bf3b359d.1a1e88","type":"api-current-state","z":"53aabe5c.55603","name":"Garage Door Closed?","server":"613f67e5.e69a28","version":1,"outputs":2,"halt_if":"closed","halt_if_type":"str","halt_if_compare":"is","override_topic":false,"entity_id":"cover.garage_door_mqtt","state_type":"str","state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","blockInputOverrides":false,"x":1140,"y":800,"wires":[["87ecae59.f487a"],[]]},{"id":"8c0ed406.476668","type":"api-current-state","z":"53aabe5c.55603","name":"Garage Door Open?","server":"613f67e5.e69a28","version":1,"outputs":2,"halt_if":"open","halt_if_type":"str","halt_if_compare":"is","override_topic":false,"entity_id":"cover.garage_door_mqtt","state_type":"str","state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","blockInputOverrides":false,"x":1140,"y":880,"wires":[["e00344ed.566978"],[]]},{"id":"87ecae59.f487a","type":"change","z":"53aabe5c.55603","name":"Open Garage","rules":[{"t":"set","p":"payload","pt":"msg","to":"open","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1360,"y":800,"wires":[["d9c45e63.3f094"]]},{"id":"e00344ed.566978","type":"change","z":"53aabe5c.55603","name":"Close Garage","rules":[{"t":"set","p":"payload","pt":"msg","to":"close","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1360,"y":880,"wires":[["d9c45e63.3f094"]]},{"id":"b9e57d24.80b1c","type":"mqtt in","z":"53aabe5c.55603","name":"","topic":"nodered/Garage/command","qos":"2","datatype":"utf8","broker":"4d42f578.4cd4ac","x":610,"y":840,"wires":[["4fdc9198.65939"]]},{"id":"4fdc9198.65939","type":"switch","z":"53aabe5c.55603","name":"Open or Close","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"open","vt":"str"},{"t":"eq","v":"close","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":880,"y":840,"wires":[["bf3b359d.1a1e88"],["8c0ed406.476668"]]},{"id":"9df3db3c.d07ee8","type":"inject","z":"53aabe5c.55603","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"open","payloadType":"str","x":670,"y":880,"wires":[["4fdc9198.65939"]]},{"id":"f6e4e3a1.e133e","type":"inject","z":"53aabe5c.55603","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"close","payloadType":"str","x":670,"y":920,"wires":[["4fdc9198.65939"]]},{"id":"bbf82f95.bea51","type":"switch","z":"53aabe5c.55603","name":"Open, Closed, Opening & Closing","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"open","vt":"str"},{"t":"eq","v":"closed","vt":"str"},{"t":"eq","v":"opening","vt":"str"},{"t":"eq","v":"closing","vt":"str"}],"checkall":"true","repair":false,"outputs":4,"x":640,"y":740,"wires":[["27d98cc8.1e2f54"],["27d98cc8.1e2f54"],["27d98cc8.1e2f54"],["27d98cc8.1e2f54"]]},{"id":"27d98cc8.1e2f54","type":"mqtt out","z":"53aabe5c.55603","name":"","topic":"nodered/Garage/status","qos":"2","retain":"","broker":"4d42f578.4cd4ac","x":1080,"y":740,"wires":[]},{"id":"4d42f578.4cd4ac","type":"mqtt-broker","name":"","broker":"192.168.0.10","port":"1883","clientid":"Node-RED","usetls":false,"compatmode":false,"keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","closeTopic":"","closeQos":"0","closePayload":"","willTopic":"","willQos":"0","willPayload":""},{"id":"613f67e5.e69a28","type":"server","name":"Home Assistant","legacy":false,"addon":false,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true}]
- platform: mqtt
name: "Garage Door MQTT"
device_class: 'garage'
command_topic: "nodered/Garage/command"
state_topic: "nodered/Garage/status"
payload_open: "open"
payload_close: "close"
payload_stop:
The lovelace config is still the save as above.
