Hi all - just got my Garadget and in the process of setting it up. I have a Liftmaster with Security+ 2.0, so I also bought the one-button remote adapter to wire in to Garadget. I’m also integrating through Control4. So far, everything has gone smoothly, and I’m able to interface with Garadget from C4. I was able to connect to Wi-Fi, and the door will OPEN fine, but when I try to close Garadget, all 4 lights flash on the Garadget and then it appears to go through the reset sequence (one, then two, then two solid and one flashing LED). Opening still works fine if I manually move the Garadget back to closed status and open up again. I’m definitely doing something wrong - but what?
Thanks in advance -
Steve
