Is anyone else having issues with IFTTT integration not working now? It looks like that as of 6/11 all of my applets for Garadget in IFTTT have stopped working. When I view the status of the applets, it just says there was an error.
Anyone have any thoughts on how to get it working again?
Yup I had the same issue this morning. Been perfect for months and then this morning had it say it was opening and closing all morning around 5am EST. Got an email that my applet has been turned off. When I went and “checked the applet said there was issue with applet trigger.
It looks like under one of the applets. For example , notify when garage is closed. In the section where you select trigger. I can’t select anything and it says no trigger found in the little pull down box. As such, the applet won’t run because it doesn’t know what trigger.
Super odd it’s not “updating” to allow me to add my trigger.
The integration tests come through without any issues. Please try re-authenticating the service on the chance that the previous auth token got expired.
I’m New to having issues (been a long time since I’ve had issues)… I’ve never had issues since first day I bought it). To reauthenicate, is that just sliding the authenticate slider and then using my password or Touch ID (on iPhone)?
Ok I went there, clicked on edit connection, typed in login credentials, and it takes me back to the same screen showing account is active but have test account… advice moving forward? Do I disconnect?
When I go into the settings for the applet, it appears that the location is reset to a default of somewhere in San Francisco. I’ll reset to my location, but then I still get the error.
@TheMerg,
Do you experience the same issue with both the IFTTT app and their web?
The location trigger in your apple is IFTTT’s feature, we can try and troubleshoot it with you but ultimately it’s under their management.
Okay, I went in via the web and the location was set back to San Fran. I updated it to my address (Northern VA) and saved it. I went back in and verified that it was still showing as my address. I then used the iOS IFTTT app and went to the settings for the Applet and it was still set for my address. I’ll keep trying to remember to check it to figure out when the address is reverting.
I would guess that the location reverts to default when the account is re-authorized. Don’t see why that would make sense, but it’s probably the trigger.
Garadget’s IFTTT authentication code was switched from 90 day tokens to non-expiring tokens some time ago so hopefully this was the last time you needed to re-authorize.
Mine recently failed, too, and I got it working again about 90 days ago after the previous problem. I wish I didn’t have to re-auth IFTTT every quarter. (I wonder if this is related to the mobile app sometimes prompting me for credentials…)
That is strange. I am using IFTTT on an iPhone without issues. I used the Garaga skill to allow me to Open and Close my garage door from my Apple Watch (Series 3). The best thing is that I do not have to have my iPhone with me to open and close the door.
