ifttt notify on open and the notify on close stop working for me. seems like a drop-down list to select the door needs to be selected but I have only one door and it doesn’t appear in the list.
I have had that happen in the past, usually you have to either reconnect garadget to IFTTT so it gets its permissions back or disconnect garadget and reconnect again in IFTTT. It is an IFTTT problem and it seems to happen at random but it is an easy fix, the only problem is if you have to disconnect and reconnect then you have to set up your recipes again.
Disconnect and reconnect worked. Thanks!
