Can get the door open when installed but won’t close. I tried to simulate with the reflector. As the usb cord is very short for my setup.
Also, looks like my led’s are now out on the control pad? Suggestions.
Normally the Garadget’s relay contacts are opened and only close for the fraction of the second when there’s a command from the client software. There should be no effect on the rest of the system when Garadget is connected.
If something doesn’t work as before then it’s likely due to the disruption to the existing wiring.
You can always disconnect Garadget and check if anything changed.
You can check if Garadget handles the commands by listening real close to the barely audible “tick” when relay is activated. Another method is to use continuity tester on the terminals.
