Hi All. I thought it might be interesting for people to know that I figured out how to install Garadget with a Marantec Highline 10.2 which does not have a wired open/close button. It’s actually quiet simple: connect the two wires to connections 1 and 2 at the connector which is called XB01 in the manual. Works like a charm. The only thing I still have to find out is how to actuall fix the wires (I just pushed them in and it works, but I suppose fixing them with screws or so would be better). The connector sits roughly above the light, so you don’t have to open anything.
Robert,
Congrats on your successful Garadget install!
Please post a picture of your final setup when you’re done fixing the wires.
Thanks!
Just a small addition to the Marantec door: it was actually very simple to fix the cables: just push in the red buttons above the opening with a small screw driver, push in the cable and release the button: that’s it. Here is a photo of the result.
Those look like the connectors on my opener and are a spring loaded push fit so don’t need any screws to hold the wires into the terminal.
