Hello, all was working fine up until few days or even week not sure. I have tried multiple “M” and “R” but no luck. When the unit is inside the house it connected fine but as soon as i move to garage the unit doesn’t connect. As mentioned this was working fine.
Sounds like a WiFi connectivity issue. Something must have changed. If the signal was marginal a small thing like angle of the antenna on the router or neighbour installing a RF noisy LED bulb can cause a disruption. You can try powering Garadget from a power bank and move it around to see what is the furthest it can maintain connection.
WiFi signal buster might help. Also Garadget can be equipped with the external WiFi antenna.
