Nice Spido wiring
Greetings! I intend to buy the product, but first I’d like to make sure it works with my Nice Spido (SP6000) garage door opener. I don’t have a wall mounted push button, I open/close the door using a remote.
The manual can be found at https://manuals.easygates.co.uk/PDF/misc/IST103.4858-1.pdf
From the description of the Step-by-step button it sounds like it should work with Garadget.
You can test that by momentarily shorting terminals #5 and #8 when door is open and that should close it. Shorting them when the door is closed should open it. Optionally: shorting the terminals when the door is in motion should stop or reverse it.
Shorting does work, thank you.
