Opener with only one wire for wall switch?
Hi.
My opener only has one terminal input for wall switch, but I need two for the Garadget? Isn’t it possible to use my opener with Garadget then?
It looks like you should connect the Garadget to the PB and GND terminals.
Yes, the second wire is either GND or +24V. I’d check the user manual for more information.
This can also be determined by measuring the voltage at PB pin against GND. To make button work and light up the LED in in the wall console, there’s difference of potentials between the connections. If PB reads around zero (in technical term: pulled down), then the other pin for the wall switch is +24V. If it reliably reads any stable voltage above 3V (pulled up) then the other terminal is GND (0V).
