Had Garadget unit for awhile now. Last night came home to red triangle with exclamation “!” offline". Followed all troubleshooting steps on forums. Wifi connection is good. Replaced power supply. Tried setting up as new device. Android phone sees unit, but unit will not connect. Please advise
Clarence,
As mentioned in email, the first thing to try is setting up your Garadget while it’s not mounted on the opener.
You can remove M4 screw holding main enclosure to the mount to bring your Garadget closer to your phone and router.
