Here is the code I put into my HA configuration.yaml.
mqtt:
cover:
- device_class: 'garage'
unique_id: "298u9823983249hd928"
command_topic: "garadget/<name_created_during_setup>/command"
state_topic: "garadget/<name_created_during_setup>/status"
value_template: >-
{% if value_json.status == 'closed' %}
closed
{% else %}
open
{% endif %}
payload_open: "open"
payload_close: "close"
payload_stop: "stop"
sensor:
- name: "In state for"
value_template: '{{ value_json.time }}'
- name: "Brightness"
unit_of_measurement: '%'
value_template: '{{ value_json.bright }}'
- name: "Reflection percent"
value_template: '{{ value_json.sensor }}'
- name: "WiFi power"
unit_of_measurement: 'dB'
value_template: '{{ value_json.signal }}'
- name: "WiFi SSID"
state_topic: "garadget/<name_created_during_setup>/config"
value_template: '{{ value_json.ssid }}'
I’m no Home Assistant expert and the whole process took me quite a lot of digging and googling and piecing things together. To that end, I’ll try and write it all up here, and hopefully anyone else trying to get Garadget running with MQTT and HA will have an easier time.
First things first, you need to set up a local user login in the Mosquitto Broker add-on. Settings->Add-ons->Mosquitto broker->Configuration (tab at the top). You’ll need to add a user under logins. You can add a username and password as plain text:
- username: your_username
password: your_insecure_visible_password
However, I didn’t like the idea of a plain text password sitting there visible and there are instructions that say “You can also optionally set a password
value using the hashed password obtained from the pw
command (which is present inside the Mosquitto container). If doing so, you must also specify password_pre_hashed: true
alongside the username
and password
values.” Using the command below:
pw -p "<password>"
(yes, leave the quotes)
This will generate a hashed password that you can copy into the password field. Seemed simple enough, but I didn’t know how to run this command in the “Mosquitto container.”
In order to be able to run the command, you need to have the add-on “Advanced SSH & Web Terminal” installed and the “Protection mode” toggle on the “Info” tab turned off, then the add-on restarted. I got a nice, red warning about protection mode being turned off at the top of the add-on. Launch Terminal and then run the command:
docker ps
Example output:
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
6e7ae15c6cfc ghcr.io/home-assistant/generic-x86-64-homeassistant:2024.5.4 "/init" 3 hours ago Up 3 hours homeassistant
ac2752f3f0ab homeassistant/amd64-addon-mosquitto:6.4.0 "/init" 5 hours ago Up 5 hours 0.0.0.0:1883-1884->1883-1884/tcp, :::1883-1884->1883-1884/tcp, 0.0.0.0:8883-8884->8883-8884/tcp, :::8883-8884->8883-8884/tcp addon_core_mosquitto
a0a77ecfa6d8 ghcr.io/hassio-addons/ssh/amd64:17.3.0 "/init" 5 hours ago Up 5 hours addon_a0d7b954_ssh
Find the container ID of the image containing amd64-addon-mosquitto
. Now you can run that pw
command as such:
docker exec <container_id> pw -p "<password>"
Example output:
docker exec ac2752f3f0ab pw -p "test"
PBKDF2$sha512$100000$KDMIksYvx0Yv/tFmr3pR8Q==$grB05mGMFZumWBiBubfK+iNKV0u+ou7xc4GS9EC7r0ghvzRJTq8uffyIPoKbQv2FBydR1+Zr3f2HXTB1tDS+UA==
Copy that hashed string into the Mosquitto broker Configuration login field for the password.
Example:
password: PBKDF2$sha512$100000$KDMIksYvx0Yv/tFmr3pR8Q==$grB05mGMFZumWBiBubfK+iNKV0u+ou7xc4GS9EC7r0ghvzRJTq8uffyIPoKbQv2FBydR1+Zr3f2HXTB1tDS+UA==
Hit save on this. I noticed that it modified the password line to put the entire password on the next line.
At this point, you can finally connect your Garadget device to MQTT [Original instructions]. Hold the M button until it slow flashes dark blue, connect to the Garadget WiFi (PHOTON-XXXX) and open 192.168.0.1 in your browser.
Select your WiFi network, give it the WiFi password. I opted to use the cloud and MQTT. Give it the IP of the MQTT broker (your Home Assistant IP) and port 1883 (assuming you’ve made no changes to the default). Give it the username and password that you set up in the Mosquitto broker Configuration. Save that and hopefully Garadget connects to WiFi and the light turns solid cyan. On a few occasions during my testing I had to repeat all these steps a second time before I got connected.
You can paste the code from the top into the configuration.yaml file, save it, reload the YAML configuration under developer tools, and you’ll have a garage door that you can open, close, and get some stats on.
I had initially tried setting up Garadget’s MQTT connection using a Home Assistant username and password I had set up in HA’s People because a lot of documentation and forum posts seemed to indicate that you could log into Mosquitto broker with a Home Assistant username and password. When I checked the Mosquitto broker logs, I would see that my Garadget was trying to connect but it was unauthorized. Going through all the steps above finally got Garadget visible and operable in Home Assistant.
I hope this can help the next person trying to work this all out.
