Does anyone know how I can wire to
This Wayne Dalton Quantum opener?
The model of the opener is not visible in the picture (only make), but there are only three terminals, two of them are connected to the wall button. Those are the terminals to which Garadget should also be connected.
It only says Wayne Dalton Quantum. I’ve tried the various combinations and have not had luck
From what I was able to fine online it should be middle terminal (COM) and one below it (PB).
To confirm, you can try shorting them with a short piece of wire to see if that activates the door.
Worked perfectly. Thank you.
