Thanks heaps for the reply.
I’m a bit lost. As far as I can tell, I have the correct ID/Token.
Regarding the missing config, I assume I need to update that to the port, name and username to that of my homebridge?
I’m going to try attach a screenshot of my entire config.
Really appreciate the help
xNinjas
42
No looks like its there. How I get the token is by logging into garadget and inspect the page
Mine looks slightly different but definitely says access token:
Does this look like the right place?
I see the token has now changed since i last looked
xNinjas
44
Yes, “/doorStatus?access_token=”
the token should look different each time just do not logout close the window and that token should work.
Argh, same thing unfortunately. (token expired).
No worries, i’ll have a play around thanks heaps for your help.
Cheers
