[ question] Larger Laser Target Tape?
Hello, I am wondering if it is possible to purchase a larger laser target so I don’t have to keep constantly adjusting my Garadget (not Garadget’s faut). Something like 8"x8" would be perfect.
hungns35
Try searching for 3M reflective tape. It’s out there.
Please see following posts for the reflective tape suggestions:
Hi. I had a similar issue. My garadget was attached to the garage door opener and would move. I moved it to a beam nearby and that solved the issue.
I don’t know if that’s what you are experiencing nor if this is possible in your situation, but thought I’d suggest it.
