Hi I have been using simple commands to enable me to use Siri to open and close the garage door.
I only use simple commands for this singular function. Is there an alternative option? I would have thought it would be an opportunity for the Garadget developers to add a paid Siri integration to their app?
You can expose Garadget to siri by running Homebridge. I do this and am quite pleased with it. I get home, ask Siri to open the garage as I drive up to my house…
If you aren’t familiar with Homebridge, it allows one to integrate non-Homekit enabled gadgets to work directly with Homekit.
If you have a bit a tech acumen it’s really not that hard to enable. You can run it on a spare PC, Mac or Linux box. I use Linux, so I just picked up a Raspberry Pi, installed noobs, and then Homebridge. Works like a champ! See this post, it’s what I used : HomeKit Integration with Homebridge-Garadget Plugin
There is also a way easier way to install the base of homebridge ( https://homebridge.io/ ). after you install it you can find me garadget plugin easily and install it. after you do have to configure it.
Gosh its been a few years. If it gets more interest i could update my instructions with this new. Been meaning to add a donation link
