Anyone having problems getting signaling to a chamberlain door system? Everything else looks good but seems like it does not send any signals to the first two ports (the first two inputs are the up/down - from left to right on the chamberlain.
Russell,
There are few methods to verify that the Garadget is actually handling the command from the mobile device:
low tech: put your ear next to the unit and hear a gentle âtickâ from the relay
use the continuity tester on the Garadgetâs terminals
If relay functions then the problem is in wiring. Keep in mind that the incorrect wiring attempt may fry the relay in Garadget and whatever else what on the other end of it.
Iâve got the same chamberlain opener (same wiring). I was not able to get the door to open with the unit. I talked to Dennis and he had a test to make sure the wiring to the opener is working correctly. If you remove the cable from the garadget unit and short the two wires together with the screw driver for a quick second, that will simulate the relay inside the unit. I tried this on my opener and it wouldnât open. Iâm going to have to do some more research on this opener tomorrow and see what we need to do to make it work. Iâll keep you posted on what I find.
From what I researched the two on the left are the correct terminals for Chamberlain. If your wall button works fine then I suspect there is no good contact for Garadget wires at the openerâs terminal.
You can pull out the wall button wires from the openerâs terminal by pressing the tab below, then match the length of the copper on the garadget wire with the old wire, the put them back together side-by-side, maybe twisted for good measure.
Thereâs often additional circuitry in the wall button for extra functions (like locking the radio out and controlling the light), but good old short of the wires is normally reserved for the door motion. The duration of the short is configurable in Garadgetâs settings.
Based on more research yellow âlearnâ button means security+ 2.0 opener. They replaced toggle button with the proprietary serial protocol. You can see the related discussion in this thread.
Guys, I have the chamberlain lift master. I can get the garadget to work fine (cyan led) and the wall button inside the garage works but the oem remote button and my cars programmed button only works inside the garage, not on the outside of the house. Do I need to reprogram it? I didnât think so. No idea why.
If remotes werenât programmed correctly then they wouldnât work inside of the garage either.
Check if you accidentally messed up the antenna on the opener. Often itâs just a black single wire sticking down.
Also, it would be a rare coincidence for both remotes, but try them with fresh batteries.
I have the Chamberlain B970, and was initially able to configure and connect the Garadget successfully⌠it stopped working recently. Not sure whatâs changed, but now when the garadget unit makes that clicking noise (relay) when itâs activated, it doesnât trigger the Chamberlain. Iâve reconnected the connecting wires, cut and stripped them again to ensure contact, but still no joy. I can hear the unit click, and can see the Chamberlain acknowledge the trigger by the up/down buttons blinking a few times (up, down, down, down, and the middle blinks green ever so slightly), but no open/close actually happens. And the manual wall button works fine, which is connected to the same wires the garadget unit is connected to.
After researching this a bit more⌠the up/down/down/down lights are error codes that indicate a âshort in the door controlâ. But the wall unit (which is connected in the same spot) works as expected with no error codes/lights, and Iâve already replaced all the wires from the garadget to the Chamberlain. Oddly, while the wall button works as expected, if I short the two leads (which the garadget does), it activates the up/down/down/down error code. That makes me think the âshortâ isnât the right âsignalâ (so to speak) to activate the door⌠but it all worked before!.. so that canât be it. Go figure.
David,
Yes, according to the manual your opener is Security+ 2.0 and therefore requires an adapter in order to work with dry contact controls like the relay in Garadget.
So Iâve purchased an additional Chamberlain remote, soldered on the wires, connected it to the garadget and now it all works as it did before. I had forgotten I replaced the garage door motor/mechanism after I had configured it the first time⌠and it didnât work with the new Chamberlain unit due to the new Security+ 2.0 thing. Works now though with the additional remote workaround!
